I experience this one today. I use my phone on taking photos while I'm in the pool. At first, the phone only detected that there is a moisture inside my port. Until I decided to used a hair blower to get rid of it. And then, there is no longer notification. Afterwards, I charged my phone. A few minutes later, an indication of moisture detected. And so I detached the my phone to charging cable. Then, I use my phone to take photos again.
But then, when I turned it on, there is a sign of damaged lines like there is a darker lines and normal lines. And I thought this won't last. Then, I took pictures only in front camera since there is a sign of moisture inside the back camera. And so this suddenly happens..
After taking photos, I do edit pictures through phone. And suddenly, with a 26% battery, my phone blacks out. ??..I started to panic since I've tried all the solutions I have searched in the internet.
And I finally, decided to open the phone trying to fix it myself since I can't afford to pay repair for this in the service center. I found some areas wet. And I tried to open it using the Power On + Volume down. But still nothing works after cleaning. (I didn't do unscrew anything).
The last thing I did today was use an UV sanitizer that I bought in the midst of pandemic. I only put the phone that I opened at the back in the UV Sanitizer (for about 10-15s) and I use the solution I found on making it open ( Power On + Volume up for a 10s). And viola my phone is now working. I am so happy that I want to share to everyone what I did to fix my phone (S10e). Hope it works for you also. I think UV devices can help dry the moisture inside the phone. Feedback me at alleyiahshyne@gmail.com
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
26 commentaires
can anyone help me b/c my lg g stylo fell and now the screen is black and i dont know what to do....plz help
par Helder Villanueva
i have the same problem. my samsung e5 mobile has dropped down, now i cant able to see the display, the display is blank now after changing the display also, can anyone help me please
par Ramesh Nice
i took my Samsung S6 active to the pool and water got inside the phone, now the screen is purple and pink and the screen is barely visible but it still functions , and i dont know how to fix it
par Jonathan Campos
<a href="https://www.youtube.com/watch?v=XELRW1-u... ">try this out</a>
par anuragsharma2479
dear Jonathan, i had the same story today. can you or anyonw else hear help me. it seems that there is a gap between what Samsung specs and the reality...
par Yardi Sh
Voir 21 commentaires en plus
