Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 23
Total : 11,377
1 commentaire
Thanks oldturkey03! I will check this out immediately.
par Berry
