Mac only types in caps
Anyone know how to fix this and yes, caps is off but still types in caps. I went to system preferences and it looks right. any suggestions
²naythan
it would always be a great idea to start a new question for that matter.
anyhow - first of all - use your setup disk to remove the password (use this guide (click))
after the system restarted, try to kill the caps lock function, i only guessed this - but maybe the mac "thinks" he had received the caps lock code from the keyboard (keyboards are working with codes)
use this guide (click) to try it
+ links
to kill the caps lock function: https://www.maketecheasier.com/disable-c...
did you try to reboot your MacBook ?
i've read that sometimes this could happen and the problem was gone after a reboot.
if a reboot won't fix it - what happen if you switch caps lock on ?
I rebooted about 20 times and nothing, when the caps is lit still types in caps..
I tried both of your suggestions, didnt work. Im assuming its the keyboard..thank you for trying
to bad - maybe you should try a usb or bluetooth keyboard before you go out and buy a new topcase
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 16,568
