How do I clean mbp after coffee spill?
Spilled coffee with sugar and milk on the right side of the keyboard on my macbook pro. Immediately set aside the computer and dried most of liquid off, then turned the machine off and more intensively dried with a cloth. Turned it back on (which I now realize wasn't the wisest move, and I'm very lucky nothing got fried) and everything worked, so I put it to sleep and left it while I went to work.
After work (about 5 hours later) I found the keyboard keys weren't working right (no response to occasional response from enter, spacebar and delete keys, and one of the directional keys seemed to be constantly active - computer making bumping sound like incorrect key pressed), so I powered the laptop off and opened up the back to see if there was any liquid inside. The machine was bone dry inside, dust undisturbed with the only oddity being a slight coffee smell coming from the optical drive corner (drive was a little hesitant to release disk inside - took 2 tries to eject disk), but no smell anywhere else. Left the computer upside down for about a day to dry out some more (powered off) and popped off and cleaned the keys that weren't working with a damp cloth (water - dried thoroughly before popping back in place).
Powered the laptop on the next day and everything works except the keyboard. No response at all from any key, and the backlight only appears to be working in the very center of the board. However the computer does not sound as if it's working too hard, no overpowered fan noise, just operating normally. Currently is powered off and upside down with a small cooling fan on the keys.
Tried further drying by setting rice over the keys for a few hours, which was a mistake. Took a few hours to get the rice out that had seeped to the internals of the machine. I think there is still a rice piece stuck under the optical drive, but don't have the correct tools to pry it out yet.
Recently ordered a torc screwdriver to see if I can clean off the drive with some isopropanol, but not sure if I should replace the keyboard or not. Is there a way to fix it without replacing the whole thing? Would cleaning it with isopropanol as well help it? Should I try to clean everything since rice did get inside the machine?
1 commentaire
My last attempt to turn my mac on left me a little fearful as the keys began to respond again, but not in the way they should have (pressed delete and got a letter on screen). It also befuddled me that my login screen popped up, when I have always had my mac set up to go directly to my home screen without a forced login. It had never acted up like that before, so I actually ended up taking it into the Geek Squad and am glad I did. It needed not only a new keyboard, but a new power button (which made sense to me as the power button was very hesitant to respond) and hard drive! Just lucky that I backed up my important files before sending it off! Expensive lesson, and I now have my mac ensured for any future problems. Thanks so much for your input!
par Emily
