As Oldturkey says....the video "card" on a laptop is built into the motherboard, it's a big IC soldered direct to the board. If the video system fails, you need a new motherboard. A rare few laptops have separate video cards, high-end machines such as Dell's XPS line. But, given the age of this system it's probably not worth repairing unless you can find a known-good motherboard and do it yourself.
When laptop video starts showing those color symptoms, you need to know if it's happening during boot or only after Windows loads. If it's only after Windows is launched, might be a driver or other Windows problem. If the colors are there during the BIOS screen and POST, or when you boot to some CD/DVD such as the Windows install disk, then the hardware has a problem, and this is a major problem.
Attaching an external monitor before booting will help....if the external monitor looks ok then you have either....a bad cable between the motherboard and LCD, a bad LCD, or a loose connection in that cable.
Cette réponse a-t-elle été utile ?
A voté
Annuler
Indice
0
