iPhone Gets Hot While Calls and Gameplay!
My iPhone 3G gets hot after about 2mins on calls and about 15mins during gameplay....is this normal????
If not, how do i go with repairs?
--Jeremy
--Jeremy
Hi,
if you play games, it's normal that the phone, depending on the kind of game you play, needs a lot of power. So the battery gets uncharged quickly and gets warm and also the electronics on the logic board is getting warm.
Nearly the same when doing a call. I don't know where you live, but when the connection to the net is very low, or the antenna is covered, the phone will use more power to maintain a stable line. The rest is the same as above.
Is it getting warm, that's normal, or is it getting hot(like more than 40°C)?
Well.... I have a case on and i can feel the heat through the silicone case and the case's rubber gets a bit mouldy. P.S the phone works perfectly!
i was told my battery was going to break down so replaced with a new one i dont know if this is true though but my iphone dose not get quite as hot as it used to this is just my experiance that i had
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,045
1 commentaire
I edited your post by adding your case gets mouldy
and i also added "If not, how do i go with repairs?
par Nick
