Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A smartphone by Samsung running Android, identifiable by the model number GT-S5570, released in 2011.
I forgot my Galaxy Mini password, how do I reset it
As I switch my phone on, It requires a (pattern) password and I have forgotten it
Répondu ! Afficher la réponse J'ai le même problème
Indice 23
3 commentaires
Did you set a pin number incase you forgot your pattern?
par
No I never set a pin number
par
wifi and bluetooth not working
par
Ajouter un commentaire
2 Réponses
Solution retenue
Hi,
If you make some wrong entries the phone will offer you to log on with your google account. But you must have WiFi connection. You can't make new connection and your WiFi must be turned on from before.
The second way is with adb commands. But for this you must have enabled USB Debugging from before. Otherwise you can't connect it with the PC.
The third way is Factory Reset but you will LOST all your data. Push and hold together vol(+) and power on keys.
With vol(-) chose Factory Reset. The power on key is for ok.
Samsung Galaxy S5 - Supprimer le mot de passe/code de dévérouillage
Regards.
Indice 6
1 commentaire:
omg it worked thank you and keep up the good work
par
1-code formati https://www.facebook.com/rebels.tn.3
2-conneceter sur wifi entre email et mot passe
Indice 2
Ajouter une réponse
King James sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 34
Total : 15,691
