Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le quatrième smartphone de Nexus, sorti le 13 novembre 2012.
Nexus 4 screen regularly blacks out when make a call
The screen on my Nexus 4 regularly blacks out when I make a phone call. This has got worse since I had the screen replaced recently. I can hear the call but I cannot then use the screen to switch to speaker and worst of all I cannot disconnect the call. If I keep intermittently pressing the on/off button the screen will flash intermittently and if I keep hitting where the disconnect bar is I can after a while hit it just at the right time and I get my screen back. Nightmare! Is there a remedy to this fault?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
6 Réponses
Its not actually a fault, its so your phone doesn't start ending your call or changing things when its pressed up against your face, as this activates the touch screen similar to when your fingers move across the screen. If you remove it from your face and wait a few seconds at most it will switch the screen on again and you can end your call.
Indice 0
1 commentaire:
well let them know they are stupid and that makes their fones just as stupid like they are. nice when the government or the bank ask you to press 1 or 2 0r 3 ect... and you cant. super duper stupid fone
par
You CAN make it so that lock button ends your call in settings, have a look under settings for how to do this or do a quick Google search :)
Indice 0
1 commentaire:
oh nice. so you end your call with the goverment you waited half hour to reach when they ask you to press numbers. very smart cell crap.
par
the problem is associated with the proximity sensor. in order to fix it just remove the screen protector from that region. mind you it is not a software or hardware problem. its just the type of proximity sensor in the nexus 4. due to this you are advised to use thin screen protectors or just avoiding the sensor area.
trust me it works.
Indice 0
1 commentaire:
and how the HECK you do that?
par
Do you use a display foil? If yes, check if the foil covers the distance sensor in the upper left of the phone.
Indice 0
1 commentaire:
wtf it all mean?
par
I have had the same problem also since replacing the screen.
I am not certain but i think the problem might be a screen protector on the inside sensor porthole - one which needs to be peeled off before installation. I tried doing this before fitting the new screen but couldn't just peel it off. I ended up sort of scratching it off badly with some bits left behind.
Either way it still didn't work for me but if what people say about screen protectors is anything to go by this could be an issue.
Indice 0
The remedy is a weird one.
You must remove the logic board. When you do this you will see the proximity sensor on it has a black rubber covering with two holes. One big and one small.
Take the rubber covering off and flip it.
I'm not sure why it works, but I've used this to fix this problem dozens of times
Indice 0
Ajouter une réponse
Jashim Quraishi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 2,716
