How to heat it without Microwave
How do i heat the iopener without a microwave ? Oven heating ? Boxed in water bath ?
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
Tho oven works. I heated the iOpener for 20-30 min. initially at 160°C / 320°F. While using it to open a ipad I reheated it several times for 5 min. Completed the job successfully.
Don't use the water bath. The oven might work, but it will take longer, most likely, and probably won't work as well. My recommendation is that you should either get a microwave, do the repair at a friends house with a microwave, or use a heat gun.
Under any circumstances DO NOT USE AN OVEN FOR HEATING IOPENER! Heated mine for 15 min at 170 degrees and the thing melted down. I was stupid enough not to check the oven the whole time. The plastic broke and that hot liquid was all over my oven.
It may be possible but for future reference 20 min and 170 celcius is way too long.
Commentaires:
it is said it should only be heated for 30 SECONDS NOT 15 MINIUTES
par nixon nelson
Yes this is true for microwave. A regular Oven heats up stuff in a different way and therefore takes longer time. Thats kind of the point of microwave - it heats up food fast
par laur
Heated 5 mins in 140C oven and worked perfectly. Whenever cooled down, just popped it back in 140C oven for another 5 mins. Bit slower but did fine.
par Joe
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 48
Total : 3,116
