Aller au contenu principal
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
Questions au sujet de 72 Voir tout
Transmission fluid—how many quarts to fill?
How many quarts of transmission oil for my 2005 Ranger 4WD?
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
its a 1992 ford ranger 5 speed
par
patsymiller0, 1992 Ford Ranger 5 speed manual transmissionApprox 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
https://www.youtube.com/watch?v=AC8lhIcK...
par
Ajouter un commentaire
4 Réponses
Solution retenue
Raleigh, Ford says that the transmission holds 10 quarts on two-wheel drive models and just under 10.5 quarts for four-wheel drive models for a complete change.
Indice 4
3 commentaires:
08033530020 Mr ola
par
Four wheel drive
par
@Olayanju Suraju what make, model, year?
par
Uses less if you don't drain the torque converter.
Indice 2
2 commentaires:
Well how manny qrts is less if u dont drain the TC??
par
Generally the tc holds about 4-5 quarts
par
Cette réponse correspondait à l'origine à une autre question .
According to the Owner's manual :
2005 Ranger Auto Transmission Fluid - use Mercon V
4x4 with 3.0 and 4.0 engines use 10.3 Qts (9.8L)
Note the 4x2 uses 9.9 Qts (9.4L) with the 2.3L engine and 10.0 qts (9.5L) with the 3.0/4.0 engine
Indice 2
Raleigh /patsymiller0, If a manual tranny, Ford Ranger 5 speed manual transmission Approx 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
Indice 2
1 commentaire:
How many liter atf for my ford everest 2005 model automatic transmission
par
Ajouter une réponse
Raleigh sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 81
30 derniers jours : 438
Total : 52,364
