Aller au contenu principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 questions Voir tout
Need a good source for taking apart a 23" HD Cinema display
Does anyone have a good source (an Apple service manual would be ideal) of instructions for taking apart a 23" Apple HD Cinema Display (Aluminum)? I've poked around online but haven't found anything great. Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 6
1 commentaire
I have the Cinema Display take apart. Email me at fedguy2@ pacbell .net
par
Ajouter un commentaire
8 Réponses
Solution retenue
Try this link. Ralph
http://docs.google.com/viewer?a=v&q=cach...
Indice 3
8 commentaires:
Oh my. Any bets on how long that stays online before Apple's legal team has their way with it?
par
I don't think so (or they aren't able to properly use a search engine).
oh, somewhere between the n and the t is one of the search results ;-)
par
On the basis of Kyles remarks the OP should download this material now. Ralph
par
can you reup please?
par
Try this: service
par
Voir 3 commentaires en plus
Once inside, check the VR3 3.3VDC REGULATOR center pin to make sure it is putting out 3.3v, bad one will put out about 4vdc. It is very common problem with this 23" aluminum case.
See my pictures here:
http://s807.photobucket.com/albums/yy352...
Indice 3
1 commentaire:
Hi
I have a blank screen (No Lights or display) I have followed your advice and tested the VR3 Regulator. Center pin is 1.96 DCV and Right pin 5.1. Assuming this show that it is faulty I was wondering the part number i should order and maybe where you were able to source it.
Also being surface mount is there any issues with DIY or would it be worthwhile finding a new board.
Thanks in advance
par
i've found a korean website - but the main focus is "looking inside" and not the "show others how to do it": CLICK
and a disassembling "guide" for the 20" CLICK
Indice 2
1 commentaire:
The first link is for an acrylic monitor but the one at the bottom is what I need. Thanks.
par
I have the 23 dvi version if you need another manual let me know.
Apple Cinema Display 23" HD DVI Manual
Indice 1
1 commentaire:
Thank you for the link and pdf!
par
All manuals.
http://tim.id.au/laptops/apple/
Indice 1
lokk at this master from Cile he helped me sure //// A1097 Broken Power Adaper fix for a 23" Apple Cinema HD Display. copy and look at Youtube good lycka
Indice 0
Does anyone still have this display service source pdf around? I need to take mine apart and can't find the service manual anywhere...
Indice 0
Add me to the list of people needing a dissassembly guide. My new-to-me display has mould on the inside of the screen :( Heartbreaking.
Indice 0
Ajouter une réponse
jasonnrogers sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 26
Total : 35,986
