Is it a automatic or 5spd.?
If it's a 5spd. It could be the clutch start safety switch. It's located on the clutch if you look down in the floorboard with a flashlight push the clutch in with one hand while looking to see if the switch depresses all the way in. Try putting it in neutral with the E-Brake on. With one hand or foot press the clutch hard and start the car at the same time if no, use your hand so you can see it actually touching the circuit.
If it's a automatic here the list to check off to lead you to the problem.
1.) are you possibly out of gas?
2.) with it quiet, turn the key to the on position, listen for a humming sound, if you don't hear that it might be your fuel pump the humm will be coming from the rear flip the key to position 2. And it will be a quiet humm for about 2seconds. If you hear a humm go to next.
3.) pull a spark plug wire off and lay it against metal have someone crank the car, if you see a spark move on, it's not that
4.) so, at this point, just so you understand what your trying to achieve. With a car, you need A,) spark, B.) timing C.) Fuel , & fuel pressure. D) water to keep it cool
Unplug your negative battery terminal, 30 sec. Plug it back up and try it.
5.) Check all of your fuses, there's 2 fuse boxes 1 under the hood, 2.) inside either on the kick panel to the left of the clutch, maybe under the steering wheel or behind the glove box.
6.) does the motor sound any different when trying to crank it? Maybe like its turning faster check for a missing belt
A voté
Annuler
Indice
2
18 commentaires
Roy Urena "but it doesn't turn over or start please help" how did you check the starter?
par oldturkey03
How to determine if it is a gas pump issue .. It cranks but no start 5speed
par Maca noia
I have a 97 honda accord and am having serious issues with this car. It starts up and then it'll cut off while im driving. Then it will either crank right up or might take a while. But today i got in to crank it up and sounds like something broke. Now it sounds like a hushing noise or vacuum. Did i just break my car?! Someone please help. I have a new battery, starter, spark plugs, and solenoid.
par msmom612
ignition switch!!!! they have been recalled on all 1990-2014 honda accords civics. had a 97 accord lx as well and did the same thing kick off while driving but would start right back up or sometimes would have to wait a while. after i replaced the ignition switch it never did it again... (keep in mind it could be the neutral safety switch as well. a short in either system and your car will die where ever if feels like i recommend to replace the ignition switch first cause it is a cheaper fix then the neutral safety switch.
par Franklin McKown
Hello everyone, I had the same issue with my 1995 honda accord that while i was driving for like 20-30 minutes the car would shutoff on me. so i took it to my local honda dealership to have them to diagnose it for me, they tried to charge me $595.00 for an aftermarket distributor but i have a friend that has her own autoparts shop that I got a brand new one for $150.00. I had my mechanic friend install that for me and my car has been running great for over 3 years now.
par Andrea
Voir 13 commentaires en plus
