Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Originally released in 2001, identified by model number VT750DC.
What do I do if the motorbike does not stay on?
While riding the motorbike, the engine will shut off and it will not start back up. When I try to start it back up, it makes a constant continuous chugging noise but the engine will not turn over.
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Réponse la plus utile
If the bike is carbureted and has been sitting for an extended period of time there is a chance that the float valve is sticking in the closed position. This will prevent fuel from filling up on the carburetor bowl, and starve the engine of gas. I would disassemble the carburetor and give it a good cleaning with a can of carburetor cleaner. A lot of times a dirty carburetor causes similar fueling issues on older motorcycles.
Indice 2
It sounds like the gas tank is empty. Switch to the reserve tank by flipping a switch under the gas tank on the left hand side. This will give you enough gas to get to a gas station to fill up the tank. If this does not solve the issue, refer to the troubleshooting guide for additional information.
Indice 0
It could be a battery, electrical or a fuel problem. First. Hook up a volt meter to the battery and check the voltage. It should be around 12.5 volts. Then try cranking it, it should drop a little, if it drops considerably, like down to 8 volts, you should charge the battery. Next, try spraying some starter fluid into the carb and see if it starts, it will likely cut back off shortly. If it does, that confirms a fuel issue — but it could be anything from the fuel filter to a clogged carb. Electrical—I’m not even going to touch!
Indice 0
1 commentaire:
Try the starter fluid before attempting to take the carb apart. The last thing you want to do is rip that thing apart, only to find out that was NOT your problem.
par
Ajouter une réponse
Daz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 20
Total : 1,137
