Why is my 2ds, cracked from the inside.
My 2ds, is cracked from the inside, its not cracked from the outside its cracked from the inside.
Hi it sounds like you have a broken LCD screen. The 2ds actually uses just one screen for both of the screens shown. You can purchase a replaced screen and fix the 2ds fairly easily and by following a guide here on ifixit. Remplacement de l'écran de la Nintendo 2DS
Ok so i was cleaning my corner bookself and i was putting my 2ds in the box it came in and it slid out and landed on the floor and when I turned it on it had black with white lines across the top screen. I still heard the music and the touch screen worked but i could not see through the black and white lines. PLZ HELP
If your on here it is becase you craked a 2ds this how to fix it. Frist,you buy a new screen you can get one Amozon.com then you take the back of the ds off then when you see the craked screen you very carefuly take it out then you replace it with the new one now you got a good working ds. plz comment if you nedd help on anything eles :) thankyou
How much technical skill do you need to do this and how risky is it for someone who is quite inexperienced with technology???
I did it and I barely had any idea what I was doing.
The same has happened to me. It is because the LCD screen has been cracked causing it to leak. The easiest way to fix it is just to send it into a repair shop.
what repair shop
You can buy one online from walmart for my 3ds and thare was one for 2ds for 23.00
I had the same problem I accidentally step on the touchscreen of my 2ds and I heard a snap sound and when I turned it on there was white colored cracks on both screens of the 2ds.
I have a cracked screen and the touch stopped working. The screen still comes on it just won't let me touch anything on the screen. Any ideas?
The reason why this is happening is because you need to buy a new LCD screen for your 2DS because the on you have broke.
Thanks for the answer
Can I go out and buy one somewhere instead of ordering one?
The LCD screen is broken, I'm suffering the same fate and the outer screen is not helpful, I suggest getting a case
Mine showed a gray,white,orange and red crack
I did this too it was on my bed and got crushed, all you have to do is buy a new one and replace it or bring it to a repair shop. If none of those are okay with you then just buy a new one.
my upper screen one half of the upper screen is just black
I just had this problem too, it happened right after I completed the first Mine Cart minigame of the remake of Mario and Luigi Superstar Saga. The fact that the cracks don’t appear when the 2ds is off makes me think either the cracks are inside the glass, or in the software.
My 2ds has white glowing cracks with a rainbow on it
I do not Know how to fix it but the reason that this happened is pressure on the screen. As an example if you put it in a full backpack there will be pressure on the screen.
I don’t know how to fix it but it is caused by pressure on the screen. As an Example, if you put it in a full backpack there will be pressure on the screen.
I have the same problem to when i was in gym class my 2ds was in my bag and i sat on it so then it broke please help.
The same exact thing happened to me except that, for some reason, I can still access each app in the 3DS.
Mine fell in its case from a bag on my door handle and I heard a snap I turned it on to see black with red, green, blue and whit cracks running in it but not actual cracks on the screen
Yes my cousin fe on my 2DS by accident and now it looks like a pen just busted on the inside and it's spreading
And also it's all mainly on the bottom screen but I can still come somewhat see and the games are still playable it's just the screen
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 80
Total : 35,681
31 commentaires
I have this same problem, it has happened to me twice with two different systems. Both were the black and blue 2ds, when I turn them on, it simply shows a pitch black screen with glowing white cracks running through it.
par Emily Senti
Mine too when I was at a sea world field trip it was fine but when I got home that happened to my nintendo 2ds
par cody sharpe
this also happend to my 2ds. i was walking in the stair hallway and my friend bumped me and my ds fell down the stairs. .....now i have to tell my parents =-=
par im
my ds fell off the top bunk of my bed:( now i cant play it
par James Buckle
James, the same thing happened with my 2Ds. It fell off my top bunk. I must have banged it off in my sleep, and the screen was on a metal bar in my room. I turned it on, and it was black, with cracked glass in the inside, with glowing white lines.
par Matthew Grossman
Voir 26 commentaires en plus
