Computers run slow for a few reasons. The FIRST thing you want to do is the easy things.
B4 you start, define WHEN it runs slow. On boot, on the internet while browsing, when running a specific app…..
1st - run TFC - download and run from desktop = this cleans out temp files, caches, etc. Some malware might be residing there.
2nd - run CHKDSK = open a CMD prompt and type CHKDSK C: /f = scans your HDD for errors. A major cause of slowness.
When you run this it will ask if you want to run it after a reboot. Answer yes and reboot. If you have other partitions/drives do the same for them (change drive letter). They won’t require a reboot.
If you just want to see if there is trouble on C: do not enter /f and it will run without a reboot and tell you if there were any errors. You then need to run the /f to Fix the errors.
3nd - run SFC = in the same command prompt type SFC /SCANNOW = this will fix any system file errors
If it comes back saying it found errors and could not fix them, then you will need to run DISM
You must be online for this to run
DISM.exe /Online /Cleanup-image /Restorehealth
All of these will take a long time, especially CHKDSK if it finds errors. Just wait for it. I have had it take all night to finish.
At this point, test it. If it is still slow you need to run a complete AV scan.
After that, if it is still slow, boot in safe mode to see if it still runs slow. If not, then you have an app that is using a lot of resources.
Open Task Manager to see what it might be and close any that are using a lot.
If it is still slow, a RAM upgrade might be needed. This would be indicated if it runs slow with your browser or other app.
Lastly, an upgrade to an SSD will help.
good luck
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
17 commentaires
As with all PC issues, don’t be afraid to give your computer a reboot if something’s not working properly. This can fix quite a few problems and is faster than attempting to manually troubleshoot and fix the problem yourself.You can visit here to maintain your windows problem by your self or by expert windows technician.
par Nick Sheltron
its very poor laptop in performent i buy it becouse of i5 processor 4gb ram,2gb graphic card..but it all of my wastage of money......
par gagandeep3594
I have same issue. My Asus X442UQ - 4GB Ram, i5, 2GB Graphic Card | Always freezing and running super slow. Is there any permanent fix?
par Aldridge Dagos
I hаd a ѕіmіlаr іѕѕuе, Mу ASUS laptop was running very slow.
Finally I mаnаgеd to rеѕоlvе thе рrоblеm аnd now it’s реrfоrmіng even bеttеr.
Fоllоw thіѕ guіdе hеrе: http://bit.ly/ASUSslow
Hоре this hеlрѕ
par Michael
I have Asus R558U comes with i7 7th Gen Processor + 8 GB RAM.. Putting money on brand like ASUS is wasting your time and money.. Go for DELL from my experience
par Akhil p nair
Voir 12 commentaires en plus
