Why are my fans so noisy
The fans run very loud all of the time.
When u say "all of the time" im gonna assume that they're running on high even when you're Idle. First things first, I would make sure that there are no background processes using up your CPU's resources. if thats not the case and your machine is in a properly ventilated area, then I would have a look and clean up the fans with compressed air. If this doesn't remedy the situation, then I would replace the fans. Power Mac G5 Bottom Right Cooling Fan Unit Replacement
Tutoriel
Difficulté :
Facile
5 - 10 minutes
Tutoriel
Difficulté :
Facile
5 - 10 minutes
I also recommend you install a Fan and Temp monitoring utility like SMC Fan Control.
Maj. - wait for more info before recommendations, please.
I have iStat Widget that monitors temp and fan RPM. Most of the areas are over 100 Degrees. Monday I can get an exact reading of the interior and let you know. I guess it could be overheating and not bad fans. Fan replacement looks fairly straight forward, but heat sinks I would think are a different story.
Thanks,
Gerry
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 3,497
1 commentaire
Have you done any interior work?
par mayer
