Aller au contenu principal
Released in 2012, the Toshiba Satellite C850 is a 15.6-inch notebook with a choice of either AMD or Intel processors. It has USB 3.0 and can be configured with up to a 1TB HDD for storage and discrete graphics.
37 questions Voir tout
Which RAM is compatible to upgrade Toshiba Satellite C850 X0011
My Toshiba presently has a 2GB RAM.
Can you please tell me which RAM is compatible with this laptop? 1300 MHz or 1600 MHz will that make any difference?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Tp start with here is the Toshiba Satellite C850 Users Guide: User Guide.
Here's the spec sheet: Toshiba Satellite C850
Your system uses: PC3-10600/12800 DDR3-1333 SODIMM 204pin memory. As to the memories speed You can use a faster rated module (1600MHz) but you shouldn't use a slower than what is spec'ed. In your case the speed needed is 1333 MHz.
Here's a little more detail on DDR3 memory: DDR3 SDRAM
Indice 2
1 commentaire:
With the correction of the model info: The X0011 model is newer and requires the 1600MHz RAM.
par
Ajouter une réponse
siddharth kabra sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 9,877
