Aller au contenu principal
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
Questions au sujet de 17 Voir tout
wan port not detecting internet provider
my airport extreme suddenly stopped working. I can get internet through the ethernet cable direct from provider modem to my computer but not through extreme. I have tried reset and factory reset with no success. The LED indicator on the WAN port indicates it is working but no provider is being detected. If this is a hardware problem does anyone know of a possible repair.
Répondre à cette question J'ai le même problème
Indice 6
2 commentaires:
What does Apples AirPort Utility tell you?
par
Did you get things working?
par
Ajouter un commentaire
1 Réponse
Apple AirPort Extreme is a simple fix, it is either the antenna or the WiFi card.
if the WiFi light is on it most likely to be an antenna, you can get one off ebay for pretty cheap
here is the guide to fix replace it.
Remplacement de l'antenne Apple AirPort Extreme modèle A1354
if you need to replace the WiFi card, here is the guide for that.
Remplacement de la carte Wi-Fi Apple AirPort Extreme modèle A1354
Image Apple AirPort Extreme Model A1354 Antenne
Tutoriel
Difficulté :
Modérée
5 minutes
Image Apple AirPort Extreme Model A1354 Carte Wi-Fi
Tutoriel
Difficulté :
Modérée
10 - 15 minutes
Indice 0
Ajouter une réponse
wmathie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 1,057
