Transfer data from old SCSI hard drive
I pulled a SCSI hard drive from a dead Macintosh II desktop computer and would like to transfer the data to another more modern computer. Since I only want to do this one time I need an inexpensive solution to adapt the SCSI hard drive to either USB or Firewire. I could also hook up to an old PowerBook G3 to perform the transfer.
Hello,
I have this problem, too.
I have a Mac Classic of the year 1992 and it works no more because there is rust on the mainboard (it was stocked since years in a rather humid environment).
I have succeeded in opening and extracting the HDD, a Quantum ProDrive LPS (there is also an Apple label: Hard Disk 40SC) with 50 pin SCSI connection.
I have also an iMac (that one in form of a half sphere) that is still working and has already USB, as well as Windows PCs.
How may I read the disc?
Only on Mac or also on Windows?
Best regards
F. J.
par FJ
You'll need a Mac to use the files, but some data files are transferable to a Windows system (i.e. MS Word, MS Excel, Adobe PDF ...) or a newer Mac OS-X based system.
So if you don't have a Mac you can use a Windows system which also has the needed software to read Mac drives: 4 Ways To Read A Mac Formatted Drive In Windows. Don't forget you still need the needed SCSI connection in your Windows PC to connect the drive.
You could even transfer your data to a more compatible drive for your Mac using the Windows system if you don't have a means to connect the SCSI drive to your Mac. Don't forget this older Mac system used OS-9 so the Mac you are planning on using here will need an older OS-X (Snow Leopard 10.6) to open the OS-9 Apps and its data.
par Dan
Hi,
Thank You for Your answer.
The iMac has as well the OS 9 as an early Os X.
There is mainly one file I'm interested in: the database file of a geneology program.
If I succeed in retreiving it, the whole work will not be done: I'll need a program that can read the file.
Quote: "Don't forget you still need the needed SCSI connection in your Windows PC to connect the drive."
I planned to use an adapter from SCSI to USB. Do You think that it could work? I could use it with the iMac, or if it doesn't work for some reason, with Windows.
par FJ
Sadly, I don't have any experience with these SCSI to USB converters. What can I say, give it a try ;-} Please let us know if it worked!
par Dan
Ok
Does someone else have an idea about this challenge?
par FJ
Afficher 1 commentaire en plus
