You are correct! Both the RAM & SSD drive are soldered to the logic board.
Keep in mind here this is intended to be the entry model for everyday users not the Pro's!
Review Apple's site for the full breakdown of what the new MacBook is all about.
I expect Apple will intro newer MacBook Pro's which will still offer upgradable storage (at least 3rd party). But the question is with internet connectivity available almost everywhere, does one always need deep onboard storage?
I'll admit I still want to carry what I need with in the one package (my files), and our company needs still dictate we do so. But, there will be a point where we too will need to bend to what the PC makers think is a portable laptop system. Apple is not alone pushing in this direction. As much as I don't like it either.
In the newer laptop systems the memory is ALWAYS soldered (welded) to the logic board. The MacBook Pro series has removable custom SSD drives that are designed for the given system (there are a few different units). Only some of the iMacs have soldered in memory. The newer systems have custom Apple SSD's. Again, different models use different SSD units. I should point out getting to the SSD is very difficult in the newer 'Thin Series' iMacs.
Update: The new 2016/2017 13" & 15" MacBook Pro Touch Bar models now have their SSD soldered to the logic board! Only the 13" Function Keys model have a removable SSD.
A voté
Annuler
Indice
3
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
1 commentaire
go find out on the Apple-website, it saids it has onboard SSD so no, you can't replace it... For that you're better of buying yourself a MacBook Pro if you want the ability to replace it's SSD...
par coengiesen
