Aller au contenu principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429 questions Voir tout
Fans Noise, Error: 4SNS/1/C0000008:TS0P--124
Hi.
I Add A SSD, Using: "OWC Internal SSD DIY Kit For All Apple 21.5" iMac 2011 Models w/ Tools", Then My iMac is Very Noise.
Apple Hardware Test Said This Error.
TG Pro Said: ODD 4350 RPM, CPU 4000 RPM.
Please Help me.
Update (04/20/2015)
Thanks A Lot.
This is the result on Temperature Gauge Pro.
Update (04/21/2015)
This is My new status:
Update (04/21/2015)
This is my (last) new status. Thank you Mayer! And every one!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Solution retenue
I've had to replace the optical drive fan in several of these. Some of the fans can be fixed by simply pushing on the center of the fan to move it back in place.
Indice 5
3 commentaires:
You said "Hi, i push on the fan and the silence return, thanks, very much. But: On TG Pro: "Fan Diagnostics: These fans appear to be not working properly: Optical Disk Drive (ODD)" What can Do?" First restart the machine and run the diagnostics again. It's Apple part # 922-9120 If you get the same failure use this guide: Installation du ventilateur du lecteur optique dans l'iMac Intel 21,5" EMC 2428
par
will this also work for the iMac Intel 27"
par
Luis, sure it will!
par
JAIME, the problem is most likely related to the sensor of the optical drive fan. Replacing the sensor and/or the fan should resolve this. Try to start under Safe Boot mode. Follow this Apple TN" OS X: What is Safe Boot, Safe Mode?. Download and install this Temperature Gauge Pro. It should help show you what your sensors are telling you.
Indice 3
2 commentaires:
Thanks A Lot. This is the result on Temperature Gauge Pro (below).
par
Boot my miMac on Safe mode and still is noisy.
par
Follow what OT has above
Also did you also get this: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. You'll need it if you are swapping the old HD for a SSD drive.
Indice 3
2 commentaires:
Thanks Dan, On what disk i need put this sensor?: HDD (Old Original, WD 500 GB) or SSD (New, Recent Adding: Samsung 850 Pro 256GB).
par
On the hard drive.
par
Boot my iMac on Safe mode and still is noisy.
Dan, on what disk i need put this sensor: HDD (Old Original, WD 500 GB) or SSD (New, Recent Adding: Samsung 850 Pro 256GB).?
Where can buy this fan or Sensor?
Indice 0
8 commentaires:
It appears you have other issuers here.
par
Please tell me.
par
Did you open it and find which fan was making noise and push on the center of them to reseat it?
par
You only need the sensor I pointed you to if you swap out the HD for the SSD. Its a link so click on the blue to learn more about it.
par
Looking at your TG Pro output looks like the HD sensor is working so thats not the issue here. Are you sure you plugged in the sensors back (or correctly) when you disconnected the cables from the logic board to add in the 2nd drive cables?
par
Voir 3 commentaires en plus
Ajouter une réponse
JAIME sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 4,134
