Camera connection issues on ar drone 2.0
How do I fix camera issues emergency
Did the drone fall from a high altitude? Check the main board for damage as well as the camera "neck". Make sure that all of the wires are connected fully. If you are not receiving any video at all it is most likely that the camera has been damaged and needs to be replaced, which in this case means replacing the entire bottom structure, which you can purchase here. You should also make sure that you have all of the necessary tools. You will need needle nose pliars and varying sizes of screwdriver bits.
What if the Camera just says Camera emergency but there is still video?
You are a light in my hobby tunnel!
how to fix video connection alert in ar drone 2.0?
even after replacing bottom camera getting same error.
Obsolete. No longer makes parts . Was told.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 3,579
