Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Une étiqueteuse électronique portable et conviviale fabriquée par Brother.
My unit wont turn on
I already replaced the ac adapter with a new one and the machine still won't turn on. I don't use the unit with batteries at all as it drains the batteries very quickly.
the screen remains blank. any suggestions?
Update
so i tested it out today with batteries and the unit turned on! Which makes me think something is wrong with the metal prong that attaches to the adapter. I also tested my adapter with my dvd player and it worked. So now I know what the problem is but can this be fixed? It looks fine to me; is not loose or broken.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
2 commentaires
i have the PT-D600 that wont turn on, or do anything at all..
par
Brother pulled an Apple on me and reversed the polarity on their 9v adapter. I made an adapter adapter (I call it an unadapter) so the center pin is the negative and now my generic 9v ac adapter works.
Pay attention to the (+)-c-(-) symbol beside the voltage requirement.
par
Ajouter un commentaire
4 Réponses
Solution retenue
noosheen, start by opening it up using these guides. Then use a multimeter and plug your power adapter in. Measure the voltage on the solder points of the jack on the logic board. It is possible that it has broken off, that you have colder solder joints or that the jack itself has failed.
Indice 2
Remember the power adapter must be center pin negative, most adapters are center pin positive, look closely where the adapter plugs in.....there is a small symbol that shows center pin negative
Indice 2
1 commentaire:
Ran into this today: opened cheap Amazon charger and switched wires, works fine now.
par
REFER TO THESE it seems
SOMEONE MAY HAVE DROPPED IT. SOMETHING SEEMS BROKEN.
Brother PT-D200 Troubleshooting
Indice 1
I have bought 2 adapters and both do not turn on the machine. I have also put in 6 brand new batteries and still won't turn on.
Indice 1
3 commentaires:
I just had this problem too. It worked great last time I used it. Plugged it in this morning and it won't turn on with the adapter. I put in batteries, still won't turn on. Any solution?
par
Same problem for me too.
par
me too. anyone get a solution?
par
Ajouter une réponse
noosheen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 22
30 derniers jours : 64
Total : 8,774
