What is the error code F-35
my machine is throwing an error code F-35 I am wondering what this refers to
Germae Fiebelkorn, F35 means that the unit is flooding because your pressure switch has failed. First open the door manually, then replace the pressure switch under the top panel mounted to the right side wall to get rid of the error. To unlock the door, remove the 3 screws along the bottom of the lower front panel. The panel will then pull straight down and off. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
To access the pressure switch, pull the washer forward and remove the 2 or 3 screws coming in from the back of the top panel. The top panel will then pull straight back, up, and off. The pressure switch is mounted to the right side wall above the tub and is the only part with several wires going to it as well as a small rubber hose. from here. Here is a decent video that should help you work on your washer.
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced. If you are not completely confident in your technical ability to safely access and check these components, I recommend calling a service technician to diagnose and repair the washer.
Looks like you copied mayer's great answer from here F35 error code appears during cycle and forgot to attach the image as well
Probably didn't even give me an up vote.
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 70
Total : 9,861
3 commentaires
How do I reset or clear the code?
par Nancy Pitigliano
Reading code 35 but no water is filling the washer why
par John Salinas
@nancypitigliano
To clear the code you most probably will have to check if the level pressure hose is OK and if so replace the water level pressure switch. See the two answers below.
par jayeff
