Aller au contenu principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
20 questions Voir tout
replace internal hard drive with SSD
Can I put a SSD into my Mac mini mid 2011. If so is there a preferred brand or special SSD to buy?
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi Stewart!
There is no problem putting an SSD in that machine. I usually prefer the Samsung 850 EVO.
Kind regards
Update
Hi Stew!
Overnight it came to my mind: Depending on your OS you should install TrimEnabler or Chameleon
If you are running the latest version of Yosemite, use the command line and type: sudo trim force enable You don't need any 3rd party software anymore.
That should help extended SSD's lifecycle.
Kind regards from Krautland
Indice 4
2 commentaires:
Its so sad, isn't it ?! Ever since ⁄ƒ⁄≈⁄† belongs to åππ@€ , censorship is not just a word, its taking place. Thats what I just found out on this last of my comments: I'm reading things, that I never wrote! I wrote Yose‚ª⁄†€! What do U read ?! Yosemite!!!!!! What I was trying to write, without being banned for bad behavior, was ' YOSESHITE '! & Now???!!! : Where is ya' ' Freedom of Speech'? Wozniak be praised:
cmd + shift + 3 ( 4 ) still works ! I've got several proofs!!!!!
Efff off & sick my Duck!!!!! I really wonder............
par
@Alexander - Keep it clean and please use proper roman characters so people can understand what you are saying.
par
I installed an SSD from scandisk from conrad Germany.
But what I tryde nothing brings this equipment alive.
Also the company Conrad comes with the righte answer.
Indice 0
2 commentaires:
Did you install the OS onto the drive before you put it in?
par
Guide daag , Joost! Well, what did do , to animate this SSD! Usually, they come unformatted or at least ' Master Boot Record ' . Did u go to 'Disk Utility' & gave it the ' GUID & Mac OS x Extented ( journaled ) format ? If Disk Utility does not see it at all ( internally & externally via USB / Fire Wire ) , give it back, its chuffed!!!
Kind regards from Moffenland
par
Ajouter une réponse
Stewart Eans sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 2,250
