It could be dead friend, but just a few questions
When you said u tried a different cord, did you also try a different charging block?
Did you try multiple USB ports on your PC and still get no change?
Has this iPod been heavily used, meaning dropped multiple times, maybe slight water spill on it, anything like that?
When you say you accidentally let it die on you, what did you mean, is this a problem you have had before and knew not to let it die? Because I have and iPhone and iPod and both of them die on me daily with no issues at all bringing them back so that's why I'm leaning toward bad battery or something else not apparent or conveyed to us in this question
I think the best guess would be either the cord, the block, or the battery in the iPod are bad, the PC wont detect it because it is not actually on to communicate with the PC, and it is not uncommon for a machine to not turn on because of one bad part being connected to the board, so if you have tested different cord, different block, and all USB ports, then the only thing left I can think of trying is a new battery for it
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
