Aller au contenu principal
Guides pour la version Wi-Fi de l'iPad Mini 2. Annoncé le 22 octobre et lancé le 12 novembre 2013. L'iPad mini 2, également connu sous le nom de mini iPad avec écran Retina, a tous les pixels de l'iPad Air dans un plus petit 7.9 " format.
20 questions Voir tout
Missing solder pad on Touch screen connector iPad mini 2
Hi guys,
We have a problem.
A customer brought an iPad 2 mini. I disassembled ipad, and I realized the touch screen connector was damaged. I removed the connector with solder iron, but one of the solder pad are missing.
what is the solution ?
thanks
Tibor
picture:
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Solution retenue
This is all wrong !!! The missing pad is 5th pad !! 5 NC - no connection !!
Yellow selection is pad 6,
oldturkey :D
Indice 2
7 commentaires:
@fixlab excellent job in finding this. Amazingly enough it took a year for somebody to catch this error. I did correct the original answer.
par
No problem ;)
par
@fixlab I have the same problem. The pads number 5, 15, and 17 are missing. Colud you help me with the schematic picture? Where could I connect the missing pads? Thanks!
par
gabor, pin 5 is nc, pin 15 is ground and 17 you can connect to the large cap to the left side of the connector. on the right side of the cap
par
Thank you daniel!
par
Voir 2 commentaires en plus
Réponse la plus utile
Iphoneszerviz Szeged, correction. That is contact #5 of J1700. It does not need anything. NC no connection
Indice 6
6 commentaires:
Very useful, Thank you!
par
By placing a jumper from the cable to the board?
par
thank you old turkey, :)
par
@oldturkey03 extremely grateful!
par
@iphoneszerviz, did you manage to repair this? Can u post a pic or explain a little what you had to do exactly? We are facing a similar prblem ourselves with the exact same pad ripped off during a connector replacement
par
Afficher 1 commentaire en plus
try to use best or recommended rework tools when you touching high tech logic boards. Here i can see one path Path damaged on your logic board.
you have two options,
1) Change the new logic board
2) Path modification : check the path destination and you may have to connect them physically
All the best!
Indice 2
3 commentaires:
circuity diagram available this iPad?
par
creativeelectron (http://creativeelectron.com/) seeking your support to find path of 8th contact - TP
par
jessabethany, seeking your support as well
par
Ajouter une réponse
Iphoneszerviz Szeged sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 22
Total : 4,827
