Why my phone doesnt charge?
my phone is not charging even if its connected to charger. at first there was this weird led lights blinking then after few moments it stays at 0% not even charging. I tried different charger but still not charging. My charger is working. Help please
11 commentaires
Sir I am also having the same problem that my mobile p8 lite doesn't charge , when I connect the charger .. the battery percentage does not increases, it stays the same .. Sir please guide me the suitable solution ... waiting for your reply ....
par masood ahmed
hello iam using huawei p8 lite my problem is that when i connect my mobile with my laptop my mobile shows the charging but not save how to fix it .
thanks
par Faraz Ahmad
Huawei p8 lite not charging even after replacing the charging port,
What else can l do to fix it please
par vumbata
i have huawei gr3 2017 known as huawei p8 lite 2017 or huawei honor 8 lite
with a battery problem
but after changing it does'nt increase in charging porectage
the screen is on when i put the charger
but there is no ''electrecity logo " in the battery poucentage
par Yass_ IN
use a good 3.0 mah charger or 2.5 mah charger. it works sum time 2mah or 1 mah charger was drain the battery's be cues of low amp and charging I-C temperate get hi and drain the mobile battery.
par TaMooR BaLoch
Voir 6 commentaires en plus
