Aller au contenu principal
Lenovo Thinkpad S440 Laptop not switching on at all.
Hi
I have a Lenovo S440 that I have had for 18 months. However today it will not power on. When I plug in the charger the led blinks 3 times to say it is charging and then when I push the power button the led lights up but nothing happens. You can not here the CPU fans or anything. Any help would be appreciated.
Thanks
Alex
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
neither of these worked, any other suggestions .
Thanks
par
Hey, I have the same problem, when I pushed the power button the led lights up but nothing else is happening. After 5s the power led turns off. Did you figured out a solution? Nothing of the answers below helped until now, hope you can help me:) and my name is also Alex:D
par
Ajouter un commentaire
5 Réponses
Solution retenue
Hi,
Try the emergency reset procedure.
Here is a link to the user manual. Scroll to p101 in the manual, section headed "Computer stops responding" and follow the instructions.
https://content.etilize.com/User-Manual/...
Indice 2
1 commentaire:
hard reset worked for me
par
Réponse la plus utile
Alex try hard reset. First remove the battery then unplug the laptop next hold the power button down for 60 seconds then replace the battery and power cord and start your computer. If this doesnt work remove the ram and leave it out of the machine for 5 minutes then reinstall. what we are trying to acomplish here is remove any static discharge that has built up in your computer. Hope this helps
Indice 5
6 commentaires:
No luck with either of these, any other suggestions.
par
if you have more than one stick of ram try only installing with one at a time try with one and then the other if it starts then your stick thats not in is bad if this doesnt work then I would crack it open and using a multi meter check the power coming into the computer to see where its not getting to
par
Thanks again for your help ,
There is only one slot for ram but i can try the multimeter thing tomorrow.
par
This worked for a Lenovo T480
par
I had to take the RAM out for 5 minutes, disconnect the AC power and take the battery out. Then I pressed the power button for 1 minute. It finally worked.
par
Afficher 1 commentaire en plus
I just took the battery and power cord out for a minute then put it back in and hold the power button for a while then it come back on.
Indice 0
Hi, just want to say I had the same problem…power LED blinking 3 times…and these suggestions worked. Unplugged, removed battery and waited for 1 minute. Thanks.
Indice 0
What happens when we’ve done all these troubleshooting steps and have zero success? Anything else it could be? Or do I now have a very light boat anchor?
Indice 0
Ajouter une réponse
aviationgeek sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 29
30 derniers jours : 196
Total : 116,702
