Aller au contenu principal
Repair and disassembly guides for Magellan GPS devices.
Questions au sujet de 61 Voir tout
My Magellan GPS 9250T-LMB wont come on
I was on the road, my GPS was working. I unplugged the power cord from the car outlet. 5 minutes later, I plugged it back in, but my GPS won't come on. To check if the cord got bad, I checked another cord, but the GPS won't come on. I opened the GPS and checked the voltage of the battery. It shows 3.7 volts. Please tell me your opinion on the problem. Thank you.
Répondre à cette question J'ai le même problème
Indice 3
3 commentaires:
Hi,
Have you tried resetting your GPS?
To Reset: Slide the power switch all the way over to the left and hold for 5 seconds. Release then try to turn on your GPS
par
es i tried slide power switch to the left like you set, but it still it not come on
par
I have the same problem and the reset did not work!
The light that shows it is plugged in to power is the only thing that works at all. How can I make it come on again?
par
Ajouter un commentaire
1 Réponse
Charge your GPS overnight take a paperclip pushing the reset button hold it for 8 seconds release it hold the power button for 8 seconds then release it that should make it come back on if it does not you need to replace the battery.
Indice 0
Ajouter une réponse
roleg1313 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,150
