Hi,
The Microsoft Lumia 535 touch screen has two versions, as you already know. As you also probably know they are not compatible / interchangeable. You can identity which one you have by the part number on the digitizer flex cable near the connector. Part No. "TC2C1607FPC-A1" is the "2C Version", the other is "TC2S1607FPC-A1", which is the "2S" Version.
As best as I can find out opening the phone and checking the part number on the digitizer flex cable would be the only guaranteed way of knowing which one you need.
Just wondering if you purchased both types (here is just one seller, of many online, http://www.etradesupply.com/nokia/nokia-... ) but prior to purchase you contact the seller to see if they would be amenable for a return / money back on the one that is not suitable. Never hurts to ask, the worst that they can say is no.
Hi @fanisk98 ,
Here is an image which shows where to look on the touch screen to see what version it is. The part number is actually printed on the flex cable. This one is for the 2C version, it shows C12C as the first four digits/letters printed.
(click on image to enlarge for better viewing)
This one is for the 2S version. It shows C12S as the first four digits/letters printed.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
3 commentaires
Thank you Jeyeff for your support.
par satyakoripella
can see the version differently? i mean, i had full broken touch screen and i unplug it and drop it..So i cant see the version behind .. Can i understand the version by the input on the phone's board? (sorry for bad english)
par fanis karageorge
i have Microsoft lumia 535 2S, the screen digitizer is broken.. at the first i didn't know there were 2 version of the screens, i just bought for 2C version.. will it be compatible ??
par rismanharyadi
