Aller au contenu principal
Mis sur le marché en juin 2009 / Avec processeur Core 2 Duo cadencé à 2,53 GHz
Questions au sujet de 168 Voir tout
Is it possible to replace just keyboard, not whole top case?
Four keys on the keyboard of my unibody MacBook Pro (model A1286) do not work: 6, y, / and =. Everything else seems to be fine, and as far as I know, no liquid has ever been spilled on it. After trying a firmware update, resetting the PRAM, and other suggestions I found online, I took it to the Genius Bar at the Apple Store. Unfortunately, I'm a month beyond the warranty period.
The "Genius" there opened it up and said that there may be liquid damage, but that he was not sure, and that it looked like at the very least the entire top case assembly including keyboard would need to be replaced. (That was the best case scenario: a $310 repair to Cupertino, two week turnaround.) But he warned that if the technicians in Cupertino diagnosed it as liquid-damaged, it would cost $1249 to repair.
Reading some forums online that pointed me here, I've gotten the idea that it might be possible to keep the current top case assembly but just either clean or replace the keyboard itself. The comments on your video for the 15" 2.53ghz unibody suggested that this repair might be far too complicated. Any thoughts on this?
BTW, even though your video was for A1286 model, the computer I have (which clearly says A1286 on the back) does not have a separate panel for the batter or the hard drive; the entire back is one solid piece. The video is very useful in giving me a sense of the complexity of the task, but I'm worried it might be even more difficult if I have a model A1286 that's even different from the one in your video.
Are there any steps you'd suggest I take, or any diagnostics I can do myself?
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
2 Réponses
Solution retenue
Some
keyboards are removable/replaceable some are not. You need to I.D. your Mac. to know if just the keyboard can be removed and worked on.
Follow this Answer for more help.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Indice 0
Commentaires:
I don't understand the downtick for this answer. Downtick canceled. +
par
All Aluminium Macbook Pros (inc. unibody) have removable and replacable keyboards and trackpads.
Many sellers on ebay sell both parts on there own; you don't have to replace the whole top case, trackpad and keyboard, if all you want/need to replace is the keyboard.
Make sure you get the correct keyboard layout to match the top case, and vice versa.
Indice 0
Commentaires:
I am working on a Keyboard replacement guide. please hold on.
par
Ajouter une réponse
mskeaney sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 5,460
