Hi,
Here is a link which shows how to replace the top motherboard in your controller. This is to show you how you gain access to the micro USB port.
The micro USB port is mounted on this motherboard. You would either have to re-solder it onto the motherboard if it was only pulled loose from the board and was not damaged or if it was damaged, remove it and replace it with a new one
Here is an Ifixit guide on how to replace the top motherboard.
Remplacement de la carte mère supérieure de la manette sans fil de la Xbox One
To replace the connector you would need the following:
1. tools to open the Xbox One controller (see guide)
2. replacement female micro USB connector (available from Ebay, Amazon etc) if the original is damaged. You cannot repair them.
3. soldering iron and tools
4. skills in soldering components on pcb
A voté
Annuler
Indice
7
3 commentaires
Someone removed connecting plug / sortie from USB output DC5V2.1A. Can it be replaced
par Judy Rudolph
My usb charging is broken can it be repaired
par Kamva Sam
i need to know how to put new one in
par JAMES STEVEN
