How can I fix/replace the pairing button?
The soft rubber part of the pairing button tore apart when it was pressed too hard with a sharp instrument, and now it seems that the button mechanism on the inside is broken since I am not able to press the button anymore at all. There is an empty space where the button used to be. I have not attempted any repair or taken anything apart yet. I was hoping that this could be fixed. Thank you very much for any help you can give me. R
4 commentaires
I followed the steps to open up the Jambox. The pairing button does not seem to be intact. All that I have is a small loose plastic piece about 1/8" long that does not look like it would work to push anything near the pairing switch (SW2).
par rdoering
Hello, does anyone know how to out the big jambox in pairing mode without the pairing button. I know theres a ahoertcut with a combination of buttons but cant remember
par Jeymys Rosario
Hi. Does anyone have any photos of what the aforementioned hard piece of plastic is meant to look like? I have removed the side panel and the soft white button on the panel is intact but there is nothing beneath so I don’t know what I’m meant to be looking for. I am loathe to totally dismantle the unit further. I’ve given it a gentle shake and there is nothing loose inside. Any help would be much appreciated.
par Michael
The SW2 switch for pairing is gone. Must have become dislodged from the circuit board. Anyone know where I can order that particular SW2 pairing switch. Thank you kindly.
par Marc
