Aller au contenu principal
Sortie en Europe en décembre 2006.
How do you fix a button that won't press?
The Wii took a tumble a while back, and since then, the eject button doesn't click anymore. Unless its positioned just right, it'll forever try to eject. How do you fix/replace an eject button?
Répondre à cette question J'ai le même problème
Indice 8
Ajouter un commentaire
5 Réponses
Réponse la plus utile
If I'm hearing you right, the console is constantly trying to eject the disc while the button is not being pressed. A solution you may want to consider is removing the button entirely (I'm pretty sure you can still eject the disc from the Wii menu). Try removing the faceplate to get to the button and remove it, to see if that fixes the problem or at the very least to clean out any broken plastic components that may still be in there. Wii Faceplate
Here's the part: Nintendo Wii Faceplate
EDIT: Whoops! Turns out you can't eject the disc from the Wii Menu. I tried through a whole episode of Seinfeld.
Image Replace the faceplate and its buttons.
Produit
$19.99
Indice 5
iFixit now has the part you need to repair your Wii (instructions linked to in BWest's answer)
Produit
$19.99
Indice 3
clean the buttons some times got dust around
Indice 0
Yes and i need you to fix it
Indice 0
the eject button can be replaced but its very small. I use a digital microscope to clearly see the solder points.
Indice 0
Ajouter une réponse
Kevin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 30
Total : 19,570
