Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Samsung Galaxy J1, sorti en janvier 2015, numéro de modèle SM-J100VPP/SM-J100H.
Why does my samsunggalaxy j1 is not opening?
When i tryed starting up my samsung galaxy j1, it doesn't start up until the point that i can use it .. it is stucked at a samsung logo on my screen and keeps on repeating until my battery is dead. Before this happend, my phone says it lacks free storage and can't recieve more msgs. Then i restarted my phone and then this happened. Please help me guys. Really need my phone to be fixed as soon as possible
Répondu ! Afficher la réponse J'ai le même problème
Indice 25
9 commentaires
it will delete all my data stored in internal storage
please add solution if any alternative
par
My phone is not starting
Its only showing galaxy J1 ace and turning off it continues like this until remove the battery
It has been charge too but still the samething
Anyone can suggest what can be done
par
i tries the hard corde 2 times but it won't let me use it at all ? why it keeps showing verizon get ready to enjoy/ Then iat the bottom it says lets get started emergency call and don't activate?
par
Please he LP me my Samsung Galaxy j1 is not working how to restore firmware...
par
My sumsung j1 do the same just shows log then went off again and again
par
Voir 4 commentaires en plus
Ajouter un commentaire
4 Réponses
Solution retenue
Samsung logo then off and does it again?
Try leaving it on charge for half an hour if that does not work you may need to do a factory reset or reload the software on the phone in order to get it working again.
To factory reset:
Hold power button + volume up + home button until Samsung logo appears. When Samsung logo appears stop holding the power button but continue holding the other buttons. Once you get into a recovery menu which usually release all keys.
Use volume keys to navigate the menu and the power / home key to select the highlighted option.
Do wipe data / factory reset. Wait for this to complete and reboot phone.
If this still doesn't solve the problem then you will need to restore firmware using Samsung Kies / Samsung Smart Switch.
Or flashing firmware via Odin via this guide:
http://updato.com/how-to/how-to-install-...
Indice 9
11 commentaires:
how to restore firmware using samsung kies?
par
how am i able tp restore the firmware on my phone(samsung galaxy j1 ace)
par
,how to restore the firmware using my phone Samsung Galaxy J1
par
What if after factory reset, it still doesn't work?
par
Sir how to repair my samsung j100 its stack showing the logo samsung and it wont even start stack at showing the logo
par
Voir 6 commentaires en plus
i try this Hold power button + volume up + home button but it doesn't work, how to restore firmware using samsung kies?
Indice 2
4 commentaires:
It's still it doesn't work to open my galaxy j1
par
Please help me to open my galaxy j1... thank u
par
Sir can u help me my Samsung j100 dead boot from logo until i restore finish not flushing need fix ty
par
Can I buy board of Samsung j100
par
Try to establish a healthy charging regimen so that your battery doesn't learn to die.
Indice 0
My screen still shows “SAMSUNG” and won’t even turn off
Indice 0
1 commentaire:
Need my phone urgently because of health problems
par
Ajouter une réponse
Ac sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 42
Total : 58,027
