Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mis sur le marché le 28 juillet 2014, le Samsung Galaxy S5 Mini est un téléphone portable comprenant une caméra arrière de 8 MP, un écran de 720 pixels, un capteur d'empreintes digitales et il est résistant à l'eau. Il a hérité de l'écran plus grand, de la batterie à longévité prolongée et de la caméra mise à jour de son grand frère, le Galaxy S5.
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
Indice 1
2 commentaires:
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
par
πως το διορθωνουμε αυτο το ποβλημα?
par
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
Indice 1
2 commentaires:
how do i fix this problem?
par
by flashing it with Odin
par
Ajouter une réponse
tonyknors sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 30
Total : 2,157
