Water damaged.. new screen but no screen response?
Hi
I have received an iPhone 6 that has been submerged in water. I took the phone apart into pieces, and let it sit in alcohol then dried it. The phone turns on, I can verify this in iTunes. It even asks me to enter the passcode to the phone to access it. Silent switch works too.
I suspected it was the display so I swapped it out with a verified working one. Still, same result. I'm now thinking there is a shortage to the pins on the logic board? I am new to this and happy to learn every day. Is there anything else I can try or do? If not, is there any way to verify this is a logic board issue? Any other thoughts what the issue could be?
Thank you very much.
2 commentaires
This sound like components have been burnt out on the board due to water damage. You should open it up again and lift up the black sticker near the LCD / Digitizer, front camera connector. Check for water damage and burn marks there. Also check the pins for any burn marks too.
par Ben
Are you referring to the sticker to the left of the rear camera?
par Gavin Youker
