How to replace the frosted glass back?
I dropped my z5 dual straight on its back and the frosted back glass has shattered. If I buy the replacement part how would I go about replacing it?
You should check the model number first if this is a dual sim version?
You can check the model number of the Sony Xperia by using this:
You can buy the back cover from here: (It fits Sony Xperia Z5 E6603 E6653 E6633 E6683)
http://www.ebay.com.au/itm/Original-Glas...
Here's the guide on how to do it: Note that you only need to do step 1 and step 2.
Sony Xperia Z5 LCD Screen Replacement
Note: Please be careful because if I'm correct there may be a white NFC sticker tag on the back cover (It is a white sticker with two golden contact points). This model probably doesn't have it. If it does, you'll need to heat it up then carefully separate it from the back cover as it is held by adhesive.
No backlight in Sony xperia z3 compact. Solución please
I did all those steps now nfc doesn't work. Maybe sticker not making contact with the motherboard. Do I need to buy a new sticker? And if I open the back cover again, will it remove all the glue, needing a new cover?
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 20,462
1 commentaire
Here is the video showing how to replace broken z5 back cover:
https://www.youtube.com/watch?v=FY2z27SA...
par kristastic1990
