Is i9505 microUSB board compatible with i9506?
Hi, will board with microUSB port for Galaxy S4 GT-i9505 work in Galaxy S4 GT-i9506? Is this part the same?
Thank you for your answers
Pretty sure it will work fine. It won't work if you put say a i9500 charger port onto a i9505/6/7 phone.
However i9505 charger ports are used on 6/7 phones.
Thank you for your answer.
If you want more info, all the micro usb ports used on the Samsung Galaxy S4 variants are the same. It's the charger port assembly that is different due to how it's made with the antenna and etc.
@benjamen50 Does this mean that the logic board with USB port, mic... for i9505 will work in i9506? Thanks
Yep, the whole charger port assembly.
Their all labeled i9505 anyway on the charger port assemblies themselves for compatible models.
The i9505 charging port flex is not necessarily compatible with the i9506. For instance there is a high chance that the menu/back touch keys will not work properly. They may trigger on their own or not respond/light up at all.
Will a i9505 charging port work in a i9500
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,373
