My Switched off automatically
My samsung s4 mini got switch off automatically and nt turning on plz help me
If your phone still does not turn on then it’s time to attempt a factory reset. Make sure to only perform this procedure if you have previously made a backup of your phone data.
Turn off the device.
Press and hold the following three buttons at the same time: Volume Up key, Home key, Power key.
When the phone vibrates, release the Power key but continue to press and hold the Volume Up key and the Home key.
When the Android System Recovery screen appears, release the Volume Up and Home keys.
Press the Volume down key several times key to highlight ‘wipe data / factory reset.’
Press Power button to select.
Press the Volume down key until ‘delete all user data’ is highlighted.
Press Power button to select and start the master reset.
When the master reset is complete, ‘Reboot system now’ is highlighted.
Press the Power key to restart the device.
If your phone still does not turn on then this may already be a hardware related problem. Bring your phone to an authorized service center and have it checked.
Firstly you should check your phone battery and then restart your phone then you have to check your battery is working file or not if your mobile battery is not working fine then you have to replace your battery.
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 1,177
1 commentaire
What is the history of this phone and how much battery % approximately when this happened?
Try another battery, if it manages to turn on try charging it. If it doesn't charger then charger port is most likely faulty.
par Ben
