Aller au contenu principal
Released in 2012, the Toshiba Satellite C850 is a 15.6-inch notebook with a choice of either AMD or Intel processors. It has USB 3.0 and can be configured with up to a 1TB HDD for storage and discrete graphics.
37 questions Voir tout
How do I clean out my fan and exhaust grill?
so my toshiba satellite keeps getting hot (Really hot) from a few hours of use
i havent cleaned out my laptop in a few years or so, i found this tutorial wherein i can clean the fan and the heating grill with a brush, but my question is. do i have to reapply thermal paste if i take apart the cooling system?
and if not is there a safer way to do it other than taking apart my entire PC just to remove dust bunnies from the fan and or the exhaust grill?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
Remove cover locate fan there should be a couple of screws securing fan remove fan use a can of blowout to clean heat sink and fan.
Indice 1
1 commentaire:
so i dont need to remove the copper heatsink?
par
Réponse la plus utile
@maxushero you should not have to routinely change the thermal paste, but if your computer is/has been overheating and you are going to resolve that, I suggest that you replace the thermal paste as well. Get it done ones and get it done right. No shortcuts for the disassembly. Use the guides.
Indice 4
3 commentaires:
it doesnt overheat at all. im just concerned because it gets Really hot (to the point where i can feel it from the keyboard) i just need to know that if i want to remove dust from the fan and the exhaust grill, do i have to re apply thermal paste? because if i remove the copper heatsink what would happen to the thermal paste that's already in there?
par
Part of the thermal paste will stick to the heatsink and the processor. So if you wipe it off you will have to replace it. If you leave it alone, you may get away with not changing it. I just feel that if you go through all the effort, then it might be a good thing to replace the paste as well.
par
Thanks! this helped me alot. all of you :) im forever in your gratitude
par
Ajouter une réponse
maxushero sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 434
