Aller au contenu principal
Le châssis W123 couvre les 240D, 300D, 300TD, 280E et plusieurs autres modèles de coupés, berlines et wagons Mercedes des années modèles 1977 à 1985.
Questions au sujet de 113 Voir tout
Why is my rear drivers wheel tilt in on top
My rear tire is tilted in on the top. What causes this? Can it be fixed?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
That is called negative camber. Negative camber is when the top of the tire tucks inwards. For a road going car you typically want to maintain a slight amount of negative camber (1 – 2 Degrees) to improve road handling. Camber improves handling by allowing the tire to apply even loading when the body rolls going into a corner. A good Alignment shop can put in a kit to fix it or you could take a whack at it yourself. Cost a lot more than a regular alignment though.
Indice 4
1 commentaire:
Lower control arm.
par
W123 has adjustable camber on lower control arm to chassis mount via eccentric bolt.
Simple adjustment, aim for 0-1 degree negative.
Indice 1
Ajouter une réponse
Mike Steigenga sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 635
