Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L’Atari 2600, ou Atari Video Computer System (VCS), est une console de jeux sortie en septembre 1977. La 2600 utilise un processeur MOS Technology 6507 et des cartouches ROM pour stocker les jeux.
What are the screw sizes for the case?
It looks like the case has four screw holes and all the screws are missing. Mine is a sears tele-games console, but I think it's an exact clone of the 4-switch atari 2600. I'd like to know the screw sizes for the case so I can put this thing back together properly!
Update
Here are the exact screws I ended up using, in case anyone else needs the info. #6x3/4" from Lowes. Model #: 490198
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Give me a second, I'll dig out mine and take a picture of the screw for you.
par Partager
Ajouter un commentaire
3 Réponses
Solution retenue
Here you go, it's about 3/4 Inches long. I put it next to an SD card for reference.
Indice 1
1 commentaire:
And all 4 are the same
par Partager
I measured the screws on my 4-switch Woody and Vader.
The short answer is you need four screws of size #6-20 (aka #6) in length of 5/8”. Details below…
Quantity 2 #6-20, ¾” length screws are at front.
Quantity 2 #6-20, ⅝” length screws are angled at rear. They are installed at an angle, parallel with the silver switches.
I think you could use ⅝” long screws for all four locations but factory used longer ones up front.
Measured sizes to help folks convert to metric…
Diameter 0.136 inches
19.7 threads-per-inch
Length: 0.725 inches and 0.600 inches
Indice 1
1 commentaire:
Thanks for confirming, just found this via brave browser search.
So for metric it will be M3.5 width (mine looked like 3mm but measured 3.4 so came here to confirm) .
For the Sixer consoles = 6 screws of 16mm (blunt tip) and 2 screws of 20mm (sharp tip).
The two 16mm screws in the middle of the console go with washers (these are part of the faraday cage securing from the outside, so leave those middle holes empty when working on cage)
If you find stainless steel screws, best to grease the ones that contact other metals, incase of bi metallic corrosion.
par Partager
Thanks man.. Heading to LOWES now!
Indice 0
Ajouter une réponse
Chris O sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 29
Total : 4,420
