Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Intel Core i5 bicœur avec 3 Mo de mémoire cache L3 de 1,8 GHz
How can I tell if it's the I/O board or the motherboard?
Water damage! Worked for short periods of time, then quit completely after about 2 weeks. Rather than replace BOTH, how can I test with a multimeter to know if it's the I/O board or the motherboard which is bad? There must be some way to discriminate between the two?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi Robert The motherboard will usually start up the fan and if there's a problem it cuts off . Is there any lights working anywhere the boards are 5volt dc the IO board is hard to test but it is possible the MB is easier but you may have voltage and the boards faulty if its the MB then it will usually try and start then go off if its not starting it may be more like the IO which is much easier to replace you need see if 5v are there and what's lighting up on start or not.
Update (08/01/2016)
The button which turns on the laptop there is 2 connections at either one there should be 5 volts you need to find a ground to test accross it will be one of the others on the ribbon cable you need to find it if you get a cct diagram of your switch itl be colour coded or you need try them all with your button connections both sides unless you know which is the supply one a diagram would be best and watch you don't short anything also a diagram of your MB and test it to itl give you +5v and your ground 0v these are the points your looking for its often difficult to get this info manufacturer maybe best
Indice 1
2 commentaires:
Where do I check for 5V?
par
Many thanks! I'll check and see what I can find inside the beast.
par
Ajouter une réponse
Robert sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 24
Total : 2,333
