I lose the signal on and off
The signal keeps coming and going at random. it might stop a minute after the last time or more than an hour, and for a random time.
Sometimes I get the message `check Signal Cable.'
The TV has gone off completely, with only the error messages showing
2 commentaires
Hi,
Does it happen on all available channels? Can you use the inbuilt signal strength diagnostic feature (usually found in the menus of most DTV) to check the signal level and quality of the TV signal to see if it is of a borderline low value?
Is the antenna cable / connections in good condition? Is the antenna in good condition and pointing in the correct direction?(Assuming you have an antenna connection)
par jayeff
Thanks, but I still think there is more to it.
I got a new antenna today, and it did enable me to get the signal again, but the TV keeps switching itself on and off at random times.
it only did this since i was away for a week and since then I find the picture disappearing and the shut-down sound, and then it comes on again at any time from immediately to more than an hour later. I can turn it back on with the remote, but it often goes straight off again.
I agree that the original antenna cable was probably damaged, but this is something else by the look of it.
Thanks though
par John Brunton
