Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
Hi, Could you clarify your question please? Have you dropped the phone and now can no longer make calls or do calls drop out while you are talking? Please provide more detail as to your problem. The better the description the more helpful the answers.
Hi, If calls are dropping out, what are the signal strength bars showing? Does it happen on outgoing call, incoming calls or both? Does it occur if using the phone with the charger connected and switched on?
The more details about what is happening the more appropriate the answers will be.
This question was migrated from http://meta.ifixit.com/Answers.
par iRobot
par jayeff
par jayeff
