Aller au contenu principal
A baby monitor made by Infant Optics, Inc. The DXR-8 features a 3.5" screen , temperature sensor, night vision, and an interchangeable lens system.
33 questions Voir tout
DXR-8 camera fell - how do I pull it apart?
I hear a little rattle or something loose inside of it. I just need to open it to take a look inside!
Update (11/04/2018)
@jayeff please see attached picture. I meant the whole thing came out not just the external add on.
Thanks!
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires
Lorena Heemsen is that rattling on the camera or the monitor?
par
It's inside the camera. I was able to slightly open up the round part of the camera but I can't pull apart the sides so that I may pull it all apart and really get in there!
par
Hello friends. The lens inside the camera got dismounted after falling on the ground. How to open the camera to put it back in place? Thanks
par
@h_mhanna Have you checked the link posted by @jayeff to see if it will help?
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Hi @ Deren Akinci,
Here’s the ifixit Infant Optics DXR-8 Camera Motherboard Replacement guide.
See the image in Step.12 as it shows where the ribbon cable connects to on the motherboard. Note the procedure written next to the image that describes how to unlock the connector to remove the cable. Make sure it is unlocked before trying to insert the cable and then lock it to hold the cable in.
Indice 1
Hi @h_mhanna ,
Here’s a link to the ifixit Infant Optics DXR-8 Lens Replacement guide which may be of some help in refitting the lens
Indice 0
1 commentaire:
Hi @h_mhanna ,
Check on the base of the camera unit if you can tell whether the "feet" have covers that can be prised out that are hiding any screws. If they are just molded plastic then the whole case may be a of a snap fit construction
par
Thanks again @jayeff!
yes it looks like the attached picture. I’ll try to take the “feet” covers off.
Indice 0
6 commentaires:
Hi @h_mhanna ,
Try the pointed end of a Stanley knife - knife with a razor blade as the adjustable cutting edge or a safety razor blade from a scraper to get in and prise them out
Worst case scenario if they wont prise out easily is to push through the centre with a small screwdriver and lift them out this way. This will destroy them but it appears as though the unit doesn't rest on them anyway as they seem to be below the level of the base.
par
Yes I’ll try to do that when I get a chance and will let you how it goes. Thanks a lot @jayeff
par
It happend the same to mine. Did you find a way to open it up?
par
I ended up sending it back. Infant optics is replacing it for us.
par
But yes once you remove the feet covers you can access the screw and open the camera. Fairly straightforward. Thanks a lot @jayeff
par
Afficher 1 commentaire en plus
my camera lens fell right out. Would anyone know where I attach those connections on the chip board?
Indice 0
1 commentaire:
how to reconnect the camera
par
Ajouter une réponse
Lorena Heemsen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 69
Total : 4,847
