Touch ID not working after screen replacement.
Hi
Any one experiencing Touch ID not working on iphone 6 after a screen replacement since IOS 10 was released.
I have replaced 100's of screen with no issues with the touch ID. I have now done two iphone 6 with IOS 10 on them and both have non-functioning touch ID. This look like it might be a similar issue as last year with error 53.
6 commentaires
that's strange, in this blog, it says even the China made iphone 6 screen can work well with IOS 10 an d nothing's wrong. http://www.etradesupply.com/blog/ios-10-...
par Kaye
I'm going to go with either the home button extension cable is damaged or the home button cable. Try extension first if not can't do much about touchID maybe you could try doing an update through iTunes, reset network settings and then restore as last resort?
par Ben
Hi Ben
I looked at both cables under the microscope and there is no damage at all. I will be replacing the extension cable this weekend just to see. If that does not resolve the problem, i will be reinstalling to original screen to see what happens.
par letmefixyourphone
Having same problem. Replaced screens on two iphone 6 phones with ios 10. Now touch ID not working. It has to be a ios conflict because I do fix phones frequently and NEVER had touch id issues fail before.
par Diana
I have replaced the flex cables as was suggested and it made no difference. I put the cable that had the touch id failure in my iphone 6 and it works fine.
Afficher 1 commentaire en plus
