Why my phone isnt updating to 4.3
My s3 gtI9300 isn't receiving the 4.3 update I am stuck on 4.1.1 but the 4.3 update is released help me please. ????
You will have to manually update the system software. Flash downloaded samsung firmware from sammobile with the matching model number of your device located either in the battery compartment on a label or on the back of your device on a label or printed on the back of the device.
How to boot the phone in download mode:
When the phone is off you can do it by holding the volume down + home button + power button until you get the text popping up with the warning message. Then hit the volume up button to boot into that mode.
When searching for firmware on Sammobile:
You can use the CSC code specified in recovery mode to help you choose the right firmware for your device. The CSC code can be used to identify which firmware comes with the carrier (service provider) and/or region that came with your device. You can google this CSC code to find out which region this is but this isn't really necessary, choosing the one that matches the sim card installed or country you are in is good enough.
Use Odin with the device booted into download mode and plugged in. Instructions on how to use Odin and flash firmware onto device are on every download page of firmware from sammobile.
If you need to turn the device off you can do so by taking out the battery for a few seconds and putting it back in or holding volume down + power for 8-15 seconds to force shut off. If it's already off, put it in download mode as explained previously before starting the firmware upgrade and initialization if you do decide to choose that.
TL:DR - Download matching samsung firmware with matching region (country) and model number and use ODIN (program) with the phone plugged into the computer and booted into Odin mode to flash the firmware using the PDA box (the firmware usually comes in a compressed zip file).
thank you sir for the instructions
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 65
